احتمال هک شدن سیستم VoIP به خاطر ارتباطات مشکوک
بپرسید
سلام دوستان ، من توی سازمانم یه cucm و cme داریم که تا حالا خیلی ایده آل کار می کرده. ولی حالا دچار مشکلات مشکوکی شده . حالا خروجی کامند sh sip connections udp detail رو این پایین ببینید . یه سری کانکشن ها هست که مشکوکه و از آدرس های public مثل 185.53.88.101 در کشور های دیگه هستن . لطفا بهم بگید که جریان چیه. ممنونم
TCO-RTR#sh sip connections udp detail
Total active connections      : 52
No. of send failures          : 189
No. of remote closures        : 0
No. of conn. failures         : 0
No. of inactive conn. ageouts : 1072
---------Printing Detailed Connection Report---------
Note:
 ** Tuples with no matching socket entry
    - Do 'clear sip  conn t ipv4::'
      to overcome this error condition
 ++ Tuples with mismatched address/port entry
    - Do 'clear sip  conn t ipv4:: id '
Remote-Agent:69.172.200.109, Connections-Count:1
  Remote-Port Conn-Id Conn-State  WriteQ-Size Local-Address
         5060       4 Established           0  -
Remote-Agent:94.23.27.164, Connections-Count:3
        61713      58 Established           0  -
        59795      35 Established           0  -
        52949       9 Established           0  -
Remote-Agent:54.36.17.110, Connections-Count:1
        62483      37 Established           0  -
Remote-Agent:172.30.90.253, Connections-Count:1
         5060      17 Established           0  -
Remote-Agent:185.53.88.101, Connections-Count:5
         5075      12 Established           0  -
         5076      50 Established           0  -
         5070       7 Established           0  -
         5071      30 Established           0  -
         5074      22 Established           0  -
Remote-Agent:145.239.206.216, Connections-Count:1
        57451      48 Established           0  -
Remote-Agent:185.40.4.28, Connections-Count:5
        58619      31 Established           0  -
        64472      21 Established           0  -
        65235      16 Established           0  -
        52791      45 Established           0  -
        63004      74 Established           0  -
Remote-Agent:172.30.20.40, Connections-Count:1
         5060      24 Established           0  -
Remote-Agent:10.140.1.245, Connections-Count:1
         5060       3 Established           0  -
Remote-Agent:158.69.126.203, Connections-Count:29
        56112      44 Established           0  -
        57639      13 Established           0  -
        62119      71 Established           0  -
        55883       2 Established           0  -
        61308      20 Established           0  -
        65354      43 Established           0  -
        56296       6 Established           0  -
        54652      10 Established           0  -
        60266      25 Established           0  -
        55905      59 Established           0  -
        54995      15 Established           0  -
        57753      68 Established           0  -
        60644      56 Established           0  -
        58922      19 Established           0  -
        64011      18 Established           0  -
        60015      14 Established           0  -
        59609      33 Established           0  -
        64593      70 Established           0  -
        57789      11 Established           0  -
        63551      69 Established           0  -
        60016      73 Established           0  -
        49579      76 Established           0  -
        59099      23 Established           0  -
        63006      41 Established           0  -
        53325      38 Established           0  -
        58428      46 Established           0  -
        62397      75 Established           0  -
        52562      77 Established           0  -
        55516       8 Established           0  -
Remote-Agent:172.30.99.1, Connections-Count:1
         5060       5 Established           0  -
Remote-Agent:158.69.241.198, Connections-Count:3
        64736      40 Established           0  -
        56332      72 Established           0  -
        49999      54 Established           0  -
-------------- SIP Transport Layer Listen Sockets ---------------
  Conn-Id               Local-Address
   0            [0.0.0.0]:5060:
#cme #مشکل_cme #هک_شدن_cme
پاسخ ها به این سوال
پاسخ ها به این سوال
{{ digitTrunc(post.likes) }}
{{ err }}
